| shaggy |
Jun 24 2006, 05:30 PM
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
im changing out my 72 1.7 for a 73 2.0
i have a rescently rebuilt tailshift tranny since ill have it seperated and im putting a new clutch in what else should i change? i cant change to side shift at this point and i dont have the money for a renn shifter should i change the bushings out? if so what ones? -shaggy |
gregrobbins Before reassembly, get your rotating parts balance... Jun 24 2006, 05:44 PM
shaggy im going to used the raby cam that will work with ... Jun 24 2006, 05:50 PM
gregrobbins What to balance:
Crank, pistons, connecting rods,... Jun 24 2006, 06:35 PM
Al Meredith If you are going to keep the tail shifter then I w... Jun 24 2006, 06:47 PM
Mark Henry You will also need to use the '72 engine bar. Jun 24 2006, 07:51 PM
Red-Beard You also should take apart the gear selector in th... Jun 24 2006, 08:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th July 2026 - 04:29 AM |
