> Electricals Question, Electrical Flasher units
Brando
post Jun 24 2006, 03:39 PM
BUY MY SPARE KIDNEY!!!
I have a question about electric flasher units. I would like to replace my incadescent bulbs/lamps with LEDs, to trim the wattage/amperage usage. I've noticed when my electrical system is under load I get a bit of extra load on my 1.8 as the alternator is working itself to death. Also when using LED lights in place of the incadescent ones, they don't pull enough amperage to trigger my OEM flasher (heat-driven).
Anyhow, does anyone make electrical flasher units? Where can I get one that I might even be able to wire in myself? I have knowledge on electrical systems (diagrams, simple circuits, etc) but nothing as complex as making my own up. Has anyone replaced their OEM flasher unit with an electrical one?
TIA.
Engman
post Jun 24 2006, 06:15 PM
Zoisite
Having just designed an led system for a euro product we are doing - I would be concerned.
I use on the euro mower I just did - 2 led turn signals on each side of the vehicle - each light draws .25A so there is a .5A draw on the flasher unit.
I went with what the lighting company recommended - (Grote Industries). When I go the led flasher relay I wanted to see it work. It did not - after talking with the tech rep there I learned that the flasher unit I got required 1A of draw to work.
I had to go to another led flasher relay that they had just come out with - requires .06A draw. It worked.
Watch your specs -
You should be able to wire it in - just get the correct wires to the correct plug on the flasher relay.
M
Brando   Electricals Question   Jun 24 2006, 03:39 PM
alpha434   Go to radio shack dot com and order one of their i...   Jun 24 2006, 03:43 PM
Brando   I found one. Not bad! Adjustable Flashing Unit...   Jun 24 2006, 04:05 PM
alpha434   Excellent find, brandon. So are you going to wire ...   Jun 24 2006, 04:54 PM
Brando   I think I'll run one for both sides and the ha...   Jun 24 2006, 05:33 PM
lapuwali   The current the LEDs draw will be well under 1A. ...   Jun 24 2006, 05:52 PM
Engman   Having just designed an led system for a euro prod...   Jun 24 2006, 06:15 PM
jk76.914
- Lo-Fi Version Time is now: 1st May 2026 - 08:09 PM
