> Electrical charging system question, Alternator?
rjames
post Jun 10 2006, 04:11 PM
I'm made of metal
I installed a brand new battery and a new voltage regulater last week in the car. My volt meter is showing 12.5 volts at the terminals. With the car running and the lights and fan on my volt meter fluctuates between 12.7 and 12.9, then slowly starts to dip, getting as low as 12.5 before I decided to shut the engine off because I could see that the battery was slowly draining.
Would it be logical that the alternator might need replacing? The alt. belt also seemed tight (not sure exactly how tight it should feel though.) I can check the electrical connections (have to find them first though.) The connections at the battery all look good though.
It doesn't look like a fun job to replace the alternator, but I'm up for the challenge. Anything else I should look for before I go this route??
Thanks!
PS: Forgot to add that the alternator light on the dash comes on when starting the car, but goes off right away once it's started and doesn't come back on at all when driving.
rjames
post Jun 24 2006, 08:51 PM
I'm made of metal
Do the test like this:
1. Put a DVOM on the battery posts.
2. Remove the voltage regulator from the relay board.
3. Start the 914.
4. Using a jumper wire, connect the D+ and DF contacts.
5. You should see 16 volts or so on the DVOM. If you do, your alternator is good
Did the test, and it showed 16+ volts. Hmm... so after doing this test I plug the voltage regulator back in, drive around a bit and what-do-ya-know, it's showing 13.3 at Idle. Nice.
The next day, I drive around and I'm back to showing 12.5 or so at idle, and when the car is off the battery is reading 12.3ish.
The one thing I haven't checked for is when it's idling at 12.3 or whatever, to short the D+ and DF contacts to see if the alternator kicks right in. Although, my guess is that it will. So I'm back to my original question- is it possible for the alternator to work correctly sometimes, and other times not? Can both of my relaby boards be causing problems? Could both my voltage regulators? Is it worth it at ths point to check the alt bulb in the dash to make sure it's the correct one? Are these still available new?
rjames   Electrical charging system question   Jun 10 2006, 04:11 PM
davep   Check the ground circuit: measure the voltage diff...   Jun 10 2006, 06:06 PM
nycchef   had a similar problem. are you sure the regulater ...   Jun 10 2006, 07:54 PM
rjames
  Jun 10 2006, 09:58 PM
rjames   I also noticed that the idle speed drops when I tu...   Jun 10 2006, 10:27 PM
bd1308   I know the regulator is brand new, but I have pers...   Jun 11 2006, 02:53 PM
jk76.914
  Jun 11 2006, 08:14 PM
davep   Don't try removing the battery from the circui...   Jun 11 2006, 08:39 PM
nycchef   i should have pointed out in my thread listen to t...   Jun 11 2006, 09:03 PM
rjames   All good info, will be testing tonight. The thing...   Jun 12 2006, 03:30 PM
rjames   I just got done reading the Pelican article regard...   Jun 13 2006, 06:09 PM
nycchef   the d+ terminal and the d field terminal are both ...   Jun 14 2006, 07:01 AM
rjames   Still hoping for some more feedback on the previou...   Jun 13 2006, 10:38 PM
Dr. Roger   http://www.toolweb.com/pics/LIS11120.jpg lead is ...   Jun 13 2006, 11:03 PM
davep   I'm still waiting to hear the results of the t...   Jun 14 2006, 06:05 AM
rhodyguy   with lights and what not on, every car i know of e...   Jun 14 2006, 09:18 AM
dinomium   I added a ground from the post to the fan shroud. ...   Jun 14 2006, 11:07 AM
Dr. Roger   a white board is a (great+brilliant=) grilliant id...   Jun 14 2006, 11:16 AM
rjames
  Jun 15 2006, 09:52 AM
Dave_Darling
  Jun 15 2006, 11:07 AM
Dave_Darling   The light is needed for the alternator to charge a...   Jun 15 2006, 10:27 PM
rjames   OK, now I'm totally confused. I switched the r...   Jun 15 2006, 11:05 PM
davep   It sounds like you have heat related resistance. W...   Jun 16 2006, 10:09 AM
Dave_Darling   Did you try the jumper test yet? --DD   Jun 16 2006, 10:37 AM
rjames
  Jun 16 2006, 11:37 AM
ClayPerrine   The only risk you have from "full fielding...   Jun 16 2006, 11:45 AM
rjames
  Jun 16 2006, 12:20 PM
rjames
Thack   Why don't you take a poll to see how many volt...   Jun 25 2006, 06:42 AM
wilchek   ditch the bosch regulator it is crap IMHO. get a ...   Jun 25 2006, 09:31 AM
Dr. Roger   when you observe 12.3 V at idle and then you put a...   Jun 25 2006, 11:24 AM
rjames
  Jun 26 2006, 02:50 PM
jk76.914   a light bulb just went off in my head... no pun in...   Jun 26 2006, 03:35 PM
rjames
  Jun 27 2006, 11:44 AM
jk76.914   Hi Robert, Well, I finally got a chance to get som...   Jul 5 2006, 01:34 PM
SGB   Hmmmm. I also experienced the "charging v. te...   Jul 5 2006, 02:13 PM
- Lo-Fi Version Time is now: 11th August 2025 - 07:25 AM
