| John |
Jun 28 2006, 12:56 AM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Eric, since you asked so nicely in the thread that we hijacked, here are some pics of my e-brakes using stock 914 brake cables. I just finished them up, and there are some slightly fuzzy pics, but here they are..... (pre-blog even)
| John |
Jun 28 2006, 05:42 PM
The SC rear calipers (having the same bolt spacing as the rear of a 914) will bolt up.
They do need small spacers to center them on the rotor. The required thickness is: (2) 1/2" SAE FLAT WASHERS I like the SAE flats as they are flat on both sides and are smaller in OD than standard washers. The spacers can be between the caliper and the mount (together with longer mount bolts) or under the rotor hat. I prefer between the caliper and the mount. The only other modification I made to the calipers was to open up the mounting holes to 9/16". This allowed me to move the caliper radially away from the center of the rotor just a little. I did not turn the rotors down at all. The rotors are stock. While the calipers cleared the rotors, I felt that I wanted just a little more room in there for thermal expansion (in case the rotors grow radially when hot). I now have almost the same clearance as a 911 has between the rear rotors and calipers. |
JOHNMAN Still another 911 e-brake thread Jun 28 2006, 12:56 AM
JOHNMAN more Jun 28 2006, 12:57 AM
JOHNMAN more Jun 28 2006, 12:58 AM
JOHNMAN more Jun 28 2006, 01:00 AM
JOHNMAN 5 clicks and they are SOLID.
I wanted to utilize ... Jun 28 2006, 01:12 AM
andys
JOHNMAN Like I said,
Jeroen do the SC rear calipers bolt straight up onto the ... Jun 28 2006, 04:19 PM
Gary I would so be interested in a kit. My 911 ebrake c... Jun 28 2006, 06:11 PM
JOHNMAN Keep me in mind in a couple of months if anyone ma... Jun 29 2006, 01:14 AM
JOHNMAN andys,
Since the return springs are what retract ... Jul 1 2006, 03:40 AM
jim912928 I'd be interested in a kit...have carrera brak... Jul 1 2006, 06:47 AM
PRS914-6 John, I am in the process of doing a similar insta... Jul 16 2006, 12:29 AM
JOHNMAN Yes you need the anchor as I call it to be welded ... Jul 16 2006, 02:46 AM
PRS914-6 I finished one side of this conversion. John real... Jul 17 2006, 11:43 PM
JOHNMAN One thing that may need to be addressed before you... Jul 18 2006, 12:15 AM
PRS914-6 John, couldn't you screw the outside cable adj... Jul 19 2006, 12:25 AM
JOHNMAN My setup is fine.
I was just warning others of a ... Jul 19 2006, 12:54 AM
Gary Hey John,
Still officially interested in a kit :D... Aug 15 2006, 10:04 PM
JOHNMAN I'm still in a busy time of my life right now ... Aug 15 2006, 10:19 PM
dion9146 Count me in too John. Not in a big hurry, but I w... Aug 16 2006, 06:16 AM
Jeroen keep us posted please! Aug 16 2006, 08:05 AM
Aaron Cox looks like a killer setup.... :)
free interest bu... Sep 3 2006, 09:17 PM
jim912928 I'm still in for a pair when you have them... Sep 4 2006, 07:41 AM
bd1308 Let me ask a stupid Q
Are these able to be put on... Sep 12 2006, 07:56 AM
JOHNMAN ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:38 PM |
