> Still another 911 e-brake thread, there are many like it but this one is mine....
John
post Jun 28 2006, 12:56 AM
member? what's a member?
Eric, since you asked so nicely in the thread that we hijacked, here are some pics of my e-brakes using stock 914 brake cables. I just finished them up, and there are some slightly fuzzy pics, but here they are..... (pre-blog even)
John
post Jun 28 2006, 01:12 AM
5 clicks and they are SOLID.
I wanted to utilize standard cables so they can be replaced if required and so others may benefit from this approach.
I created a pivot by drilling a hole in the trailing arm and welding a nut over the top of the hole (so that the threads could extend into the trailing arm. I am using a shoulder bolt with a bronze bushing as the pivot. The belcrank I designed is as thick as would easily fit inside the stock 914 cable ends (3/16"?) .
I played with the geometry until I felt comfortable that the stock brake handle would provide enough travel to actuate the e-brakes, and came up with the location of the pivot point.
I made one modifications in the middle that didn't show up well in the pics.
The 40mm anchor block that I originally welded to the backing plate was cut off of the backing plate and welded to the trailing arm for strength.
Through trial and error, I decided not to utilize the small helper spring for the bow-ties.
I am also only using single bow-ties to expand the shoes. I read somewhere that some later 911's were done that way (but I didn't verify that).
So far, they work well beyond my expectations. They feel as solid as the ones in my 911 Turbo.
(I know I need to touch up a few scratches I made in my paint. Luckily I didn't scratch through the POR-15 anywhere.
andys
post Jun 29 2006, 09:53 AM
QUOTE(JOHNMAN @ Jun 28 2006, 12:12 AM) *
I opted not to do the conversion because of my fear of using just the single bow-tie. Not sure if it is strong enough by itself.
Also, that helper spring aids in pulling the cable back, otherwise the shoes could drag. As on my Wilwood spot caliper setup, I found I needed a helper spring for this purpose to ensure the cable pulled back to it's at rest position.
Andys
JOHNMAN   Still another 911 e-brake thread   Jun 28 2006, 12:56 AM
JOHNMAN   more   Jun 28 2006, 12:57 AM
JOHNMAN   more   Jun 28 2006, 12:58 AM
JOHNMAN   more   Jun 28 2006, 01:00 AM
JOHNMAN   5 clicks and they are SOLID. I wanted to utilize ...   Jun 28 2006, 01:12 AM
andys
  Jun 28 2006, 01:42 PM
JOHNMAN   Like I said,
  Jun 28 2006, 01:53 PM
Jeroen   do the SC rear calipers bolt straight up onto the ...   Jun 28 2006, 04:19 PM
JOHNMAN   The SC rear calipers (having the same bolt spacing...   Jun 28 2006, 05:42 PM
Gary   I would so be interested in a kit. My 911 ebrake c...   Jun 28 2006, 06:11 PM
JOHNMAN   Keep me in mind in a couple of months if anyone ma...   Jun 29 2006, 01:14 AM
JOHNMAN   andys, Since the return springs are what retract ...   Jul 1 2006, 03:40 AM
jim912928   I'd be interested in a kit...have carrera brak...   Jul 1 2006, 06:47 AM
PRS914-6   John, I am in the process of doing a similar insta...   Jul 16 2006, 12:29 AM
JOHNMAN   Yes you need the anchor as I call it to be welded ...   Jul 16 2006, 02:46 AM
PRS914-6   I finished one side of this conversion. John real...   Jul 17 2006, 11:43 PM
JOHNMAN   One thing that may need to be addressed before you...   Jul 18 2006, 12:15 AM
PRS914-6   John, couldn't you screw the outside cable adj...   Jul 19 2006, 12:25 AM
JOHNMAN   My setup is fine. I was just warning others of a ...   Jul 19 2006, 12:54 AM
Gary   Hey John, Still officially interested in a kit :D...   Aug 15 2006, 10:04 PM
JOHNMAN   I'm still in a busy time of my life right now ...   Aug 15 2006, 10:19 PM
dion9146   Count me in too John. Not in a big hurry, but I w...   Aug 16 2006, 06:16 AM
Jeroen   keep us posted please!   Aug 16 2006, 08:05 AM
Aaron Cox   looks like a killer setup.... :) free interest bu...   Sep 3 2006, 09:17 PM
jim912928   I'm still in for a pair when you have them...   Sep 4 2006, 07:41 AM
bd1308   Let me ask a stupid Q Are these able to be put on...   Sep 12 2006, 07:56 AM
JOHNMAN
- Lo-Fi Version Time is now: 2nd April 2026 - 04:37 PM
