FI to carb question, got a line on a car |
terrymason |
Jun 29 2006, 12:08 PM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
I'm going to look at another 914 on Sunday. It started as a 74 2.0, but then due to a knock, the engine was replaced with a 1.8, with a carb on top.
What are the right questions to ask, and assuming a "normal" amount of rust for an east coast car, what would it's value be (hard question, I know). I'm thinking that to go from FI to a single carb on this car, they should have changed the cam and heat exchangers - is that correct? and if they didn't, what would be the outcome (loss of power I assume). Any ballpark on the cost of buying a 2.0L with FI to drop in? I'm thinking this would probably be a $4500 car, as long as it looks great inside and out. |
jimkelly |
Jun 29 2006, 12:17 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
or get a fi system for the 1.8 or get dual carbs though it probably has the fi cam.
the difference between 1.7 1.8 2.0 is not so dramatic - not enough to swap out a good motor for one of slightly greater displacement. jim |
terrymason |
Jun 29 2006, 02:22 PM
or get a fi system for the 1.8 or get dual carbs though it probably has the fi cam. the difference between 1.7 1.8 2.0 is not so dramatic - not enough to swap out a good motor for one of slightly greater displacement. jim Got an estimate for a dual carb setup? Maybe 600 worth of parts, and 500 labor? Also, if it has a FI cam, will that make a big difference? |
Lo-Fi Version | Time is now: 9th June 2024 - 09:42 PM |
