Need help with my Shifter/Clutch, Pops out of fifth gear when under throttle. |
brokenmoped |
Jun 28 2006, 09:36 PM
Member Group: Members Posts: 143 Joined: 27-May 05 From: Mission Viejo, CA Member No.: 4,152 |
Recently I've been having trouble with my shifter, or perhaps my clutch. Here's what happens: while I'm driving on the freeway (the only time I'm in fifth gear for long periods of time), cruising at about 70mph (about 3500rpms) the shifter pops out of fifth and into neutral. I've also noticed that when I'm hard on the throttle, the shifter itself physically moves a few centimeters towards neutral, sometimes popping out of gear. It doesn't do this for any other gears and I'm certain the clutch has been replaced ~20k miles ago. Here's another thing...I have a Weltmeister short shift kit that the PO installed.
Up until recently (last 3 days or so) shifting has been fine and without any problems whatsoever (I make it a point to never misshift). So am I looking at a slipping clutch or is it my shifter that is on the fritz? Thanks, Corey |
So.Cal.914 |
Jun 29 2006, 12:37 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Rubber mounts will allow the engine/trans to move a bit, your shift rod and
and shifter is attached to them. When mounts are old sometimes they allow to much movement and you will see it in the shifter. Two things I can think of could cause it to pop out of gear, first adjust your shift rod. Shifting into 3rd and 5th to hard can cause miss adjustment. Second it could be warn dog teeth on the gear it self, not retaining the synchro ring enough, keeping the gears from mating like they should. |
brokenmoped |
Jun 29 2006, 04:42 PM
Rubber mounts will allow the engine/trans to move a bit, your shift rod and and shifter is attached to them. When mounts are old sometimes they allow to much movement and you will see it in the shifter. Two things I can think of could cause it to pop out of gear, first adjust your shift rod. Shifting into 3rd and 5th to hard can cause miss adjustment. Second it could be warn dog teeth on the gear it self, not retaining the synchro ring enough, keeping the gears from mating like they should. What kind of mounts should I get to replace the rubber ones? |
Lo-Fi Version | Time is now: 11th June 2024 - 03:17 PM |
