how to remove dizzy gear?, FROM CRANK |
shaggy |
Jul 1 2006, 07:56 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
last night i got the 13mm bolt off of the end of the crank
i also was able to remove the impeller mount from the crank unsing a slide hammer i then removed the c ring from between the impeller mount and the dizzy gear but i do not know how to remove the dizzy gear. i dont want to use a screwdriver and risk damaging it and i know a slide hammer will trash it... i need to remove the dizzy gear to get the crank bushing off, unless there is another way that i dont know about... please help -jim |
bondo |
Jul 1 2006, 08:12 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
There is a special tool that hooks around the back of the gear and has a flat pad on a threaded shaft that screws against the end of the crank. It's pressed on.. You might be able to fashion something for a slide hammer that hooks around the back of the gear, but I wouldn't reccomend it. The tool is C shaped, with the ID of the "C" just the right size to fit behind the gear. The gear is on VERY tight. You might be able to rent a suitable puller.
Lo-Fi Version | Time is now: 10th June 2024 - 01:24 AM |
