how to remove dizzy gear?, FROM CRANK |
shaggy |
Jul 1 2006, 07:56 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
last night i got the 13mm bolt off of the end of the crank
i also was able to remove the impeller mount from the crank unsing a slide hammer i then removed the c ring from between the impeller mount and the dizzy gear but i do not know how to remove the dizzy gear. i dont want to use a screwdriver and risk damaging it and i know a slide hammer will trash it... i need to remove the dizzy gear to get the crank bushing off, unless there is another way that i dont know about... please help -jim |
McMark |
Jul 1 2006, 09:13 PM
Iff'n yer handy, you can use heat to take it off too. Especially the distributor drive gear, that one's easy. Heat it up (I used Oxy-Acetelyne, but MAPP would probably work and propane might) and use a nice thick leather glove to pull it off, or use a screwdriver to apply light pressure. Once it's heater up it should come off pretty easily.
Lo-Fi Version | Time is now: 9th June 2024 - 04:56 PM |
