> CHT? Car runs great until warm
hi4head
post Jul 2 2006, 04:42 PM
Hi folks,
My '73 2.0 starts and runs fine until it is warm. Then it really starts running rough. If I kick up the rpm's, it seems to help some, but not much.
I've pulled a couple of plugs and they are somewhat sooty.
I've disconnected the Temp Sensor II (CHT). When I connect my multimeter to the connector and touch ground, I get zero ohms. From what I've read, I was thinking that this should read 2000 - 3000 ohms when cold (albeit it is around 80 degrees in my garage). The sensor's connecting wire does not appear to be touching anything.
If the sensor is bad, would this contribute to the car running rich?
Thanks,
Chris
hi4head
post Jul 2 2006, 07:40 PM
I'll have to check on both points.
I managed to get a deep socket down past the tin and had the connecting wire snake out through the hole. It felt tight, but with only using my fingers in the tight quarters I'm not sure.
As far as the resistor, is that visible? Is it located in-line with the connecting wire, or down at the sensor itself?
Chris
- Lo-Fi Version Time is now: 18th August 2025 - 07:22 PM
