> Hi/Low relay for headlights., Not working or bad colum switch?
Air_Cooled_Nut
post Oct 7 2003, 05:24 PM
914 Ronin - 914 owner who lost his 914club.com
Okay, got my fogs to work. Just needed to rotate the glass/bulb housing about 1mm clockwise (IMG:style_emoticons/default/smile.gif) 35w bulbs...hmm...not very bright...maybe I'll put 55w in later. Oh, to remove the glass bezel you undo the retaining screw at the base, pry the bottom of the bezel away from the housing, then lift the bottom up and swing away from the top. The top has a catch on the inside that the bezel hooks on to (very much like a stock VW T3 headlight trim ring is attached). I'm also in the process of disconnecting them from the headlights so they operate independantly with the ignition switch ON.
Now, attached is a scan of two relays. The silver one came with the car, has part number 111 941 583A on it, and when installed the low beams are on. When I hook up the new relay (supposed to be a replacement unit) the lights do not come on. With either unit I cannot switch between hi/low beams. You can see the circuit diagram on them and they are different (great). I did try jumpering 56 to 30 and still no success.
Any ideas? Why doesn't the new black unit work? Does it sound like my hi/low column switch is bad (and how hard is it to replace)? I do have several shop manuals to help if I need to replace the column switch but, geez, I really don't want to...
PhilipT
post Oct 8 2003, 11:11 AM
Toby,
For the relay, S is the ground that controls the relay motor. When you pull on your hi/lo switch, you are grounding S, for a second or so. This transfer power for 56 to 56a or 56 to 56b and it stays that way until you ground S again. This is an interesting relay with a memory. The replacement relay needs power to 56 and 30 where the old relay had an internal jumper.
To check your switch, see if the wire to S goes to ground when you pull on your hi/lo switch.
I just rewired my 914 and thought my hi/lo switch was broken until I figuired out this relay.
Philip
- Lo-Fi Version Time is now: 4th July 2025 - 08:12 PM
