> 914-4 Ignition Switch Replacement -How to?, anybody have pics and/or proceedures?
914rrr
post Jun 16 2006, 11:25 AM
I have a suspect ignition switch in my teener. Haynes manual exploded view is so small it's worthless. Clymer only has proceedure for 914-6. Anybody have a good resolution exploded view of the steering column components and / or a step by step? Is the key/mechanical portion still available? I know the electrical switch still is. Does having AC complicate things?
GWN7
post Jul 4 2006, 04:29 AM
King of Road Trips
Download the PET from the Porsche site and look for illustration #903-20 it shows the exploded view of the parts.
http://www.porsche.com/canada/accessoriesa...-originalparts/
If your curent lock dosen't turn the switch you might need part # EN 013 042 2 It is a threaded pin that goes at the bottom of the lock assembly that turns the switch. I believe E means it's no longer available. Which means your back to looking for a used lock assembly. Unless it's broken or missing it usually is the plastic switch that wears out and not the metal part.
914rrr   914-4 Ignition Switch Replacement -How to?   Jun 16 2006, 11:25 AM
URY914   Rob Is it an early car or late? The later ones ar...   Jun 16 2006, 12:05 PM
914rrr   Paul, Thanks for the reply. 914 is a '74 (la...   Jun 16 2006, 02:29 PM
Dave_Darling   For 72-74 cars, just follow the procedure in the P...   Jun 16 2006, 04:30 PM
Thack   I took some pics from my '76. The switch is in...   Jun 16 2006, 06:08 PM
914rrr   Thanks to all, especially Dave! That is a grea...   Jun 16 2006, 08:11 PM
Joe Ricard   Piece of cake for a late one. As a matter of fact...   Jun 16 2006, 08:37 PM
914rrr   :bump: Anybody know how to remove the 930S horn ...   Jun 17 2006, 10:33 AM
Joe Ricard   It all is removeable with :sawzall: or :smash:   Jun 17 2006, 02:29 PM
Dr. Roger   Google says: The horn pad is attached to steering...   Jun 18 2006, 04:09 PM
914rrr   Thanks Doc, and all. Horn pad came of by simply tu...   Jul 3 2006, 10:48 AM
GWN7   I just did the same repair.... if the lock is worn...   Jul 3 2006, 10:57 AM
GWN7   Here's my post on this from the bad grounds th...   Jul 3 2006, 11:03 AM
914rrr   I went to the Porsche dealer. He gave me the (VW) ...   Jul 3 2006, 06:38 PM
914rrr   :bump:   Jul 3 2006, 11:54 PM
GWN7   Download the PET from the Porsche site and look fo...   Jul 4 2006, 04:29 AM
JPB   Wow, 930 wheel is on top of the sexy charts. Bett...   Jul 4 2006, 07:39 AM
Thack   I should have took pics and wrote down the disasse...   Jul 4 2006, 02:34 PM
914rrr
- Lo-Fi Version Time is now: 2nd April 2026 - 02:50 PM
