| John |
Jun 28 2006, 12:56 AM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Eric, since you asked so nicely in the thread that we hijacked, here are some pics of my e-brakes using stock 914 brake cables. I just finished them up, and there are some slightly fuzzy pics, but here they are..... (pre-blog even)
| John |
Jul 18 2006, 12:15 AM
One thing that may need to be addressed before you get too far down the path, is cable length. The passenger side is less of a concern as the cable is longer and it's unsupported distance is greater (allows more flexability).
The issue may come up where when you lower the car, the drivers side cable becomes tight and will actuate that side e-brake. When I was determining exactly what the location of the cable anchor was on the drivers side, I discovered this potential issue. As the control arm is raised up into the vehicle (as it does when you sit the car down on the suspension), the distance between the cable tube on the body and the cable anchor on the trailing arm increases. My solution was to leave enough slack in the cable that this would not be an issue under full compression of the control arm. When in the raised position, the e brake cable can touch the header on the drivers side, but when down on the ground, there is not enough slack for that to happen. |
JOHNMAN Still another 911 e-brake thread Jun 28 2006, 12:56 AM
JOHNMAN more Jun 28 2006, 12:57 AM
JOHNMAN more Jun 28 2006, 12:58 AM
JOHNMAN more Jun 28 2006, 01:00 AM
JOHNMAN 5 clicks and they are SOLID.
I wanted to utilize ... Jun 28 2006, 01:12 AM
andys
JOHNMAN Like I said,
Jeroen do the SC rear calipers bolt straight up onto the ... Jun 28 2006, 04:19 PM
JOHNMAN The SC rear calipers (having the same bolt spacing... Jun 28 2006, 05:42 PM
Gary I would so be interested in a kit. My 911 ebrake c... Jun 28 2006, 06:11 PM
JOHNMAN Keep me in mind in a couple of months if anyone ma... Jun 29 2006, 01:14 AM
JOHNMAN andys,
Since the return springs are what retract ... Jul 1 2006, 03:40 AM
jim912928 I'd be interested in a kit...have carrera brak... Jul 1 2006, 06:47 AM
PRS914-6 John, I am in the process of doing a similar insta... Jul 16 2006, 12:29 AM
JOHNMAN Yes you need the anchor as I call it to be welded ... Jul 16 2006, 02:46 AM
PRS914-6 I finished one side of this conversion. John real... Jul 17 2006, 11:43 PM
PRS914-6 John, couldn't you screw the outside cable adj... Jul 19 2006, 12:25 AM
JOHNMAN My setup is fine.
I was just warning others of a ... Jul 19 2006, 12:54 AM
Gary Hey John,
Still officially interested in a kit :D... Aug 15 2006, 10:04 PM
JOHNMAN I'm still in a busy time of my life right now ... Aug 15 2006, 10:19 PM
dion9146 Count me in too John. Not in a big hurry, but I w... Aug 16 2006, 06:16 AM
Jeroen keep us posted please! Aug 16 2006, 08:05 AM
Aaron Cox looks like a killer setup.... :)
free interest bu... Sep 3 2006, 09:17 PM
jim912928 I'm still in for a pair when you have them... Sep 4 2006, 07:41 AM
bd1308 Let me ask a stupid Q
Are these able to be put on... Sep 12 2006, 07:56 AM
JOHNMAN ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:07 PM |
