Crunchy gears, 1st, rev. and a bit in 2nd |
Mark Henry |
Oct 11 2003, 04:38 PM
I threw in a different trans but I had a problem 1st/rev before.
I resurfaced the flywheel put in a new 914 disc, used (spec good) P.Plate and adjusted it up. I had to use clearanced bolts on the fly. I still got the crunchies, any suggestions? |
JWest |
Oct 11 2003, 05:29 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Reverse crunches when you have a clutch issue.
Make sure you have the stop on the pedal board adjusted far enough up so you get full disengagement. Also check for a moving clutch tube and the items Geoff mentioned. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:14 PM |
