How did you run your oil lines?, The good and the bad...... |
PRS914-6 |
Jul 19 2006, 11:03 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I'm getting closer to installing my -6 oil cooler and lines. I have seen numerous ways of running the lines incl through the longs, under the rockers etc. but I have not decided yet. If you would comment on how you ran your lines and the positive and negatives of the end results, it would make a good thread and go perfect with the recent oil cooler thread.. Pictures would be helpful.
DanT |
Jul 19 2006, 11:39 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Mine go under gas tank up into heater down tube, behind speaker grills, into heater tubes, out into engine area to sandwich adapter...very clean.
My hoses actually run through the orginal flex heater hoses in the front cowl area and the area behind the speaker grill on the passenger side. From inside the car you see nothing out of the ordinary. also helps keep the heat from the hot oil out of passenger compartment. Here is a pic of the front trunk area. The opening you see that was cut in the bulk head was the only metal cut for the installation of the hoses themselves. Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 07:42 PM |
