> WB O2 monitoring, Which one?
lmcchesney
post Jul 21 2006, 08:26 AM
A few questions regarding WB O2 monitoring.
When using the monitor to adjust you engine, is the data stored somewhere with cooralation with rpm/throtle position? Or is it just displayed and you have to record the associated data?
Does the feed the information into the ECU like megasquirt, and the ECU adjust the A/F ratio for optimal operating?
What setup has been found to be reliable and afforable?
Thanks again,
Larry
yarin
post Jul 21 2006, 09:25 PM
'14-X'in FOOL
Gotta love the LC-1. I'm a big fan.
You can log from the LC-1 using a laptop with Logworks software which is included. However with this config you will only log AFR vs. time. If you want to buy a cheap datalogging system I would buy or build a MS I box and connect your sensors up to it and use it strictly for datalogging.
- Lo-Fi Version Time is now: 3rd July 2025 - 11:50 PM
