Help - I am so close to getting it running again ..., I am not getting any fuel?? |
vesnyder |
Jul 23 2006, 04:31 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am not sure I have the fuel lines correctly hooked up? The feed line comes from the tank, goes to the pressure regulator, then the drivers side fuel rail. Out of this rail through a connector on the motor (which has an electrical connector) then to one side of the passengers side rail. On teh opposite side of teh passengers side fuel rail is the return line to the pump - sound right?? If so, what other potential issues might there be? I will check the fuel pump next! I am so close I can hear it !!!
vesnyder |
Jul 23 2006, 06:55 PM
Fixed the fuel supply, but still no luck keeping it running? I am pretty sure it gets spark because when I use starter fluid it runs momentarily. What is the next logical problem area - injectors? I double checked the control panel connections - anything typically missed or that goes bad?
Lo-Fi Version | Time is now: 11th June 2024 - 01:13 PM |
