Help - I am so close to getting it running again ..., I am not getting any fuel?? |
vesnyder |
Jul 23 2006, 04:31 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am not sure I have the fuel lines correctly hooked up? The feed line comes from the tank, goes to the pressure regulator, then the drivers side fuel rail. Out of this rail through a connector on the motor (which has an electrical connector) then to one side of the passengers side rail. On teh opposite side of teh passengers side fuel rail is the return line to the pump - sound right?? If so, what other potential issues might there be? I will check the fuel pump next! I am so close I can hear it !!!
bondo |
Jul 23 2006, 07:36 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Do you hear the fuel pump run for a second when you first turn on the key? If not, start with that.
Lo-Fi Version | Time is now: 2nd June 2024 - 01:57 PM |
