Get turbo valve covers off w/out completely dropping engine... |
smontanaro |
Jul 25 2006, 06:08 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
So I have something going on with the six-hole on my engine. Everything I've been told to do or can think of doing to try and diagnose/solve the problem starts with a valve adjustment. No problem, except the car's got turbo valve covers that were never cut for 914 suspension clearance. If possible, I'd really like to avoid completely dropping the engine. I was thinking... (IMG:style_emoticons/default/idea.gif)
Do you think it would be possible to loosen/undo the engine and transmission mount on the right side, gently lower the engine just enough (maybe only a couple inches?) to get the lower valve cover off, raise the engine and tighten the mounts, then repeat the procedure on the left side? I'll try just about anything to lessen the jackstand time and reduce the chances they become permanently bonded to the underside of the car. That said, if I need to drop the engine, I need to drop the engine... Skip |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:38 PM |
