| vesnyder |
Jul 27 2006, 06:08 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Last night, instead of reconnecting the blower fan in the engine compartment, I sealed them off? It appears they are only there to provide a blower into the engine compartment - is this accurate? Any issues/problems with this? Heat still seems to come through - is this an integral component of the heating system?
Thanks |
| Brando |
Jul 27 2006, 08:09 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
The fan in the engine compartment assists with blowing hot air into the cabin when engine RPMs are low, as though you're parked or in traffic.
If you blocked the ports right on the fan in the engine bay, it will not blow air into the HEs, but the cooling impeller on the front of the engine will blow hot air into the engine bay (bad). If you blocked the two ports that come up on the sides of the engine (the "J" heater tubes SLITS is describing) then you just won't get hot air into the cab when you pull the heater lever. The heater lever on the center tunnel (between the seats) only works the blower in the engine bay and the cables to open the heater flapper boxes. It will only turn on the blower when it is fully up. |
vesnyder Plgging Heat Exchanger Port into Engine Compartment Jul 27 2006, 06:08 AM
SLITS If you are talking about the "J" pipes t... Jul 27 2006, 06:36 AM
vesnyder Yes, I am talking about the J-pipes - thanks. I t... Jul 27 2006, 10:49 AM
George H. ![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 04:53 AM |
