> whats inside the heater passage in the rocker box?
ottox914
post Jul 28 2006, 11:14 AM
The glory that once was.
Took the day off work, getting alot done (finally) on the SDS install. The WMS wideband will end up on the dash, and has some fairly large cables/connectors to run back to the wideband sensor and connections to the SDS ecu. I was going to run this all thru the driver side heater passage in the rocker box. While I expect there is no need for ELECTRICAL shielding in this area, how about PHYSICAL shielding. I'd hate to have a wire rub raw in the rocker box area and short out the wideband.
So, how much protection will the wires running thru this area need?
And, when I'm done for the day I'll take some progress photos and post to my SDS thread.
Eric_Shea
post Jul 28 2006, 11:20 AM
PMB Performance
Rust (IMG:style_emoticons/default/wink.gif)
Actually there's a heater tube in there. Someone should have pics. Probably a decent pic in my -6 restoration thread search "fixing the six". It might give you an idea where the cable could be run. Use rubber grommets on the holes the cable goes through... fairly common.
ottox914   whats inside the heater passage in the rocker box?   Jul 28 2006, 11:14 AM
Eric_Shea
boboli914@att.net   Some say Jimmy Hoffa :blink:   Jul 28 2006, 11:21 AM
SirAndy   some guys having fun with a heater tube ... an...   Jul 28 2006, 12:00 PM
Brad Roberts   Hey! Blast from the past. Thanks Andy! T...   Jul 28 2006, 12:05 PM
URY914   Hence the term, "hung like a heater tube......   Jul 28 2006, 12:14 PM
maf914
- Lo-Fi Version Time is now: 18th October 2026 - 08:33 AM
