| vesnyder |
Jul 28 2006, 09:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Had this issue before my recent engine pull, but it is back. When coming to a stop and push clutch in the engine just redlines? When it first happened I assume it was the throttle cable sticking, but after replacing it has to be something else? What else could it be? It is fairly random - does not happen every time I stop. The last few times I just shut it down and start it right back up, and away I go! One of these time I am going to do some damage to the motor! Any ideas on what it might be? Something part of the vacuum system or throttle body that could be sticking? Not a safe issue to have! HELP
| 914fan |
Jul 28 2006, 01:39 PM
Member ![]() ![]() Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 |
I agree. Check that the clutch cable is not pulling the throtle cable AT THE PEDAL END. I dont see how cables twisted would cause a problem. Espically since the cables are in sheeths. But you never know. I have had my clutch cable catch the throtle many times. Check at the pedal cluster in the tunel.
vesnyder Serious Engine Rev Issue Jul 28 2006, 09:53 AM
Cap'n Krusty Classic symptoms of the clutch and throttle cables... Jul 28 2006, 09:57 AM
Aaron Cox i :agree:
in the tunnel, your cables are twisted.... Jul 28 2006, 10:01 AM
Headrage :agree: Happened to me after "Dad" deci... Jul 28 2006, 10:05 AM
synthesisdv i use a little mirror to look down the tunnel from... Jul 28 2006, 10:05 AM
Demick As others have said, it is very likely the throttl... Jul 28 2006, 10:09 AM
johnc check the pedal cluster. The throttle cable ball ... Jul 28 2006, 11:12 AM
vesnyder Johnc - I just went and checked my cable and I hop... Jul 28 2006, 12:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th March 2026 - 12:16 AM |
