Can you extend the wires of the LC-1? |
lmcchesney |
Jul 29 2006, 05:18 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
OK. I was worried about leaving the controller box, it looks expensive, exposed on the tranny. Can I extend the five wires from the LC-1 sensor, over the tranny,along the side wall of the engine compartment and through the firewall? Are these wires fixed to a measured resistance for calibration or voltage generation like a cylinder head temp sensor?
Larry |
gklinger |
Jul 29 2006, 08:07 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
There's lots of good info over at the Innovate forums, including this:
Oh, are you talking about the cables from the LC-1 to power/ground/analog outs/serial? For those there is no max length (aside from using large enough gauge for 12V and heater GND). There is a max length for the serial cables though. It is 30 feet. The only real length restriction that should not be tampered with is the length between LC-1 and sensor. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:50 PM |
