914 supercharger?, i have nooo idea how this is gonna work...haha |
ziggy101 |
Aug 1 2006, 11:18 PM
Drive it like you stole it!! Group: Members Posts: 60 Joined: 16-July 06 Member No.: 6,451 |
ok...so i pulled a super charger of one of the cars in a lot, and it is a supercherger for a 4 cylinder motor. i can make it fit on my 914, but have a question or two...
first of all, is there anyway that i can get it to even turn with the motor? because a belt is supposed to turn the pulley, and i dont no how to get it to work. and second, if i DO get it working,somehow, would it even have an effect? i like the supercharger, it works fine, and i dont want it to go to waste. thanks. |
Dr Evil |
Aug 2 2006, 08:05 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Maybe you can run it from the stock 76 smog pump pully?
maf914 |
Aug 2 2006, 10:59 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Maybe you can run it from the stock 76 smog pump pully? I also thought of this, but I don't think the drive mechanism for the smog pump would be sturdy enough to drive a supercharger. The drive pulley was connected to a shaft that bolted to the inner face of the fan. The shaft ran through a bushing located in a tripod-like bracket that bolted to the outide of the fan housing. Neither the shaft or the busing bracket were especially heavy duty. A rubber v-belt then drove the air pump. The pump was fairly small and probably wasn't much of a load. I think the configuration could work, but the parts would have to be redesigned for a heavier load. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:20 PM |
