parking brake handle restoration, how does this look? |
Chris Pincetich |
Aug 2 2006, 11:38 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Phase I of the parking brake restoration is under way - the handle! Right now I am contemplating keeping this new look with a modified paint scheme. It should eventually match the rest of the interior which will be either black or polished metal surfaces. Phase II is using a NOS spring, pin, and catch on this handle.
Has anybody successfully replaced the catch? By "catch" I mean the doohiky-thing-of a bob that "catches" the teeth and moves when the botton is pushed. It looks like I might have to drill through the mount then re-attach with a threaded screw insert or something? Is there a way to clean up or replace the plastic grip and button? Phase III is getting the cables sorted and adjusting them to finally work. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Dave_Darling |
Aug 3 2006, 12:46 AM
Catch == "pawl".
The button unscrews, I haven't taken the grip off the handle though. Clean 'em up with standard plastic cleaning stuff, like the non-silicone vinyl cleaning stuff. If they're really badly faded, you might be able to make 'em look pretty again with a heat gun--just hold it on there for a few moments, and sometimes that can get faded plastic to look nice again. Or you can get some interior paint and paint the plastic. --DD |
zymurgist |
Aug 3 2006, 05:14 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I have used a fine polish (Blue Magic) to refurbish red plastic heater knobs in my 911. The hazy finish on the surface came right off and the knob turned red again. You might want to try that with the plastic brake handle.
Lo-Fi Version | Time is now: 10th June 2024 - 12:44 PM |
