> OT! Energy saving tips!
Qarl
post Aug 3 2006, 10:43 PM
Shriveled member
Our electric bills are killing us.
It doesn't help that our house is ON 24 hours since we have nurses in the house taking care of Hunter, and they of course want to watch TV.
Background info...
Our house is 5,000 sq. feet, masonry, with tile roof, and reflective film on the main windows. It was built well, and insulated well (in the walls and with blown-in insulation in the attics). We have gas water heaters and cook with gas.
Our house has three ACs (due to size) and for our son's special needs.
We also have 4 refrigerators (one huge main fridge, one regular fridge in the pantry for sodas and pizza and misc. crap, a wine fridge, and a mini-fridge for Hunter's medications (in his bathroom)
This is what we've done over the past year to help curb the bills...
1. Main House AC is at 80 all the time
2. Hunter's AC is at 78 full-time
3. Third A/C (my bedroom) is at 80 in the daytime and 74 at night (when we sleep)
4. I replaced about 24 of our ceiling can lights with compact flourescent bulbs
5. I replaced our two nightstand bulbs with compact flourescents
6. I replaced the six bulbs in Hunter's bathrrom with compact flourescents.
7. Pool pump runs only 6 hours per day to circulate chlorine
8. Spa pump runs 2 hours per day
9. Front yard lights (low voltage) are on for about 2.5 hours.
10. A/C filters are changed regularly
11. Rear yard lights are not on at all
12. Only one light is on in the kitchen at night (for the nurses)
13. The rest of the house has "nightlights" which are LED nightlights
14. Adjusted the fridges to medium cooling setting (vs. max cool)
15. Ceiling fans run on slow to circulate air.
All this has been in place about a year with negligible results.
Our most recent bill... $1,183.00 WTF! (IMG:style_emoticons/default/blink.gif)
Our bill at this time last year (before changes wer made) was around $800.00.
That being said... I do know that the utility rates have gone up 22% in a year.
So today, we decided to add to the list...
1. Keep the blinds closed in our masterbedroom permanently (they are light-blocking, foil-lined horizontal blinds)
2. Disconnected the mini wine fridge
3. Turn off the three PCs and monitors in the house when not being used
4. Reduce the number of loads of laundry by 25% per week.
5. Search for a few more bulbs to swap out with compact flourescent
What else can we do, besides move?
I don't want to live in a cave. I want to be able to enjoy the house and watch TV and have it comfortable inside. It's kind of hard when it's 95 degrees out and 90% humidity!
Your suggestions of things to look for, adjust, turn off, is appreciated
Thanks!
tesserra
post Aug 4 2006, 08:28 AM
I only circulate my pool 1.5 hrs a day.
There is no need to circulate that long.
If you have a Polaris type pool sweep with an extra boost motor, get a "Kreepy Krawly" that does not need a boost motor. These actually vacum the bottom of the pool when the circ pump is on.
Other system put the dirt into suspension in the water then depend on the filter to circulate the dirt out of the water.
Pumps stay on longer wasting energy.
I have had pools for 20 yrs with this system.
Close off all west facing windows with a reflective shade.
Good luck, I hate high utiliy bills.
zen motorcycle
post Aug 4 2006, 09:04 AM
almost not a newbie ( way less than a newbie)
I know you said you have good insulation, but how much? For your area an r49 is recommended for the attic I believe. That is in the neighbor hood of 13 inches of blown insulation. The house I have was built in the 80's, and I just increased my insulation from r23 to r49 and it made a huge difference in the amount of time the AC run. Check your AC ducts as well are they flexible or metal? Are they insulated? Are they leaking? Also you might check out two other options a geothermal heat pump and not sure on the wind situation there, but a wind turbine. Much cheaper than solar panels if you have a constant breeze. I agree with the roof color. It might not be pretty, but paint the main surface and leave the parts you can see from the ground if it bothers you too much. If you have a large TV change to a smaller LCD TV. Do you have trees that shade your house? if not get some they work great. Do you have people going in and out all the time? Look into adding an air lock. Insulated Low E windows. And keep the computers off. Most are like running 100 to 150 what light bulbs all the time and the monitor if it is a crt is another 75 to 100+
These are just some starting points. Some are expensive some are not, and the little things like AC ducting and air leaks can add up to a lot.
- Lo-Fi Version Time is now: 4th July 2025 - 03:32 AM
