Which rear shocks can get me back up to stock height or higher? |
moggy |
Aug 6 2006, 01:20 PM
Member Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
After our first rally here in the UK over the weekend (finished 34 out of 50 (IMG:style_emoticons/default/smile.gif) )I've realised we have a serious ground clearance issue. The car is simply to low and had to be walked thru the rough sections. The fronts are presently at stock height and I'm happy we can probably get the ground clearance we need at the front by adjusting the adjusters to the max and higher profile tyres. However at the back the higher profiles tyres just won't be enough.
I've presently got KYB's on the back (with 165 springs from Pelicanparts). What good quality aftermarket shocks can get me back up to at least stock height or prefereably higher? I need them to have damper adjustability and height adjustability. As far as I know my options are Bilstein or Koni......am I correct? do both shocks have both attributes I'm after? As most of the 914 aftermarket stuff is focused on lowering the suspension I'm worried that even with the spring perches on their highest settings it won't be getting me at least back up to stock height. Is my worry needless? Is higher than stock even a possibility? Also a worry is that the 165 springs I've recently purchased will be loose if I raise the suspension to this height...?? anyone have any comments on this? Thanks in advance. Moggy |
Mueller |
Aug 6 2006, 01:26 PM
for the most part shocks have NOTHING to do with height....
it's in the placement of the spring.....if you raise the bottom spring perch on the rear shock you raise the vehicle. For KYB's, you have to cut and re-weld the perch (or add spacers between the spring and the perch) For Koni and Bilstiens, you can get threaded collars which slip over the shock that allow you to custom tailor the ride height |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:39 PM |
