> Throw out arm clip, Need one soon, or could I make one????
TonyAKAVW
post Aug 5 2006, 10:19 PM
That's my ride.
Pelican Parts claims to be out of stock of this little part that holds the throwout arm onto the ball on the transmission. This (and the cup bushing) are the last pieces I need to get my engine and transmission put together and into the car. I was hoping to have it finished this weekend...
Anyway, does anyone have a good one (not cracked) they are willing to part with (in the LA area)?
Alternatively I was thinking of making something as a substitute. The OEM piece is just a piece of formed steel sheet with a nut welded on. I was thinking that with some effort I could make something out of solid steel, or maybe even aluminum. Any ideas here on what would work? The OEM piece doesn't seem to be really well made, and it seems that a solid plate of metal woudl work better.
-Tony
TonyAKAVW
post Aug 6 2006, 09:29 PM
That's my ride.
Bondo: I think you are right. In both cases there were lots of shims. I tested this part to make sure it doesn't bind through the full travel. I had to file off a little bit, but it works fine.
So in theory with a new flywheel, clutch disc, PP, and TO bearing, as well as new ball cup bushing, I shouldn't need any shims right?
-Tony
- Lo-Fi Version Time is now: 11th July 2025 - 03:41 PM
