Build your own Combo (904) Gauge, Parts 1 and 2 |
914forme |
Apr 23 2006, 06:48 PM
Well here it goes the step by step instructions on how to build one of the kits. Since I helped do the original production run, back in the day, its been about 11 years ago since we did these. But there is interest in it so I will show you how.
Step one, the original kit. It included a gauge face, a backing plate and a ground lug. Also included instructions on how to do this, and some of the items where real PITAs to do. I will included some changes I do, and items that might make the installation a little easier. Attached image(s) |
914forme |
Aug 8 2006, 03:57 PM
Next is more fun than you should legally be allowed to have. You have to add the old spade connectors back in for the old style fuel gauges - if you are using the later style - skip this step but you don't know what you are missing.
You take and hold the black plastic piece in the proper spot, add the heavy paper washer back onto the top of the spade connector, and then crimp the two side stubs, see that was easy. I split the paper washer, I will fix that with some insulating goo once I finished the soldering. Attached image(s) |
Lo-Fi Version | Time is now: 31st May 2024 - 07:55 PM |
