Galley Plugs |
Galley Plugs |
2-OH! |
Oct 17 2003, 09:19 AM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
We are going to pull the 2.0 (93,000 miles) motor out of our 1975 - 914 due to many, many, many oil leaks. It still runs very well and strong and I would like to re-build it but just do not have the budget right now.
However, while it is down, I want to check the condition of the galley plugs. Where can I find out how many there are, where they are, and how to tell if they will last another 50,000 miles or so. I read a tech article somewhere about pulling them out, tapping the holes and screwing in the pipe plugs, all, while not disassembling the engine. Do you think this process works...Internal metal shavings are hard to capture from the outside. Any Suggestions???? Thanks |
banderson |
Oct 17 2003, 10:53 AM
Member Group: Members Posts: 88 Joined: 22-August 03 From: Massachusetts Member No.: 1,064 |
Don't fix what aint broke, unless you want to take the whole thing apart.
Packing greese on the tap will capture most of the chips, but you will also need to drill out the holes to the right size for the tap. Maybe if you pressureized the oil galley, all the chips would blow out the hole that your working on. Its risky. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 08:06 PM |
