Tire question... Pressures and temps, Yokohama A0032R S compound |
ConeDodger |
Jun 24 2006, 10:10 AM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I am running a set of Yokohama A0032R S compound tires on my stock 2.0 liter Fuchs. They are 205 50 15.
I have run one event on them and just for starters I ran 35psi all the way around. After my first run the pressure rise was dramatic and I brought them down to 35psi again. from there they stabilized and by the third run they were 35psi before and after the run. I accidently left the pyrometer at home so no temperature data available for this first event. Ambient was about 85 degrees. My settings are 2 degrees negative front and 2.5 negative rear. What experiences have you guys had with these tires? What pressures have you run? (IMG:style_emoticons/default/driving.gif) |
DanT |
Aug 12 2006, 09:17 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
I ran my A032Rs at 28-30 cold. On my 914-6 with 6 inch Fuchs and 205s
ConeDodger |
Aug 13 2006, 10:42 AM
I ran my A032Rs at 28-30 cold. On my 914-6 with 6 inch Fuchs and 205s Dan your response brings up an interesting question. If you are running 205s on 6 inch Fuchs I assume you have converted to 5 lug or are in an original 6 to begin with. I put the 5.5 2.0 liter Fuchs on the Submarine 2.7 six and I easily overwhelmed the tires. Do these tires work better when spread out over a 6 inch wheel? |
Lo-Fi Version | Time is now: 8th June 2024 - 05:24 PM |
