Mockmaw |
Member ![]() ![]() Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 ![]() |
Hi all,
New engine is up and running, all very exciting. Problem is: I can't shift into 1st, 3rd, or 5th gear. I fiddled extensively with the shift linkage today.. seems adjusting the shift linkage in the 2nd-3rd plane didn't make a difference. I can shift into reverse, 2nd, and 4th fine.. when I try to shift into 1st, 3rd, or 5th it takes a huge amount of effort and finally pops 'in'.. but it's not actually in gear.. you can feel a bit of grinding if you push the shifter further towards the rear of the car, but it won't go into gear. This is pissing me off.. suggestions? |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,270 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
When you put the shift rod back in the coupler (at the firewall), you may have rotated it one spline on the end of the rod. Did you mark the shift rod and coupler so they are "indexed" together? I think this will cause the problem.
Try taking the rod out of the coupling and rotate it around one spline and then put rod back in the coupler. Paul |
Lo-Fi Version | Time is now: 3rd July 2025 - 11:58 AM |
