Transmission tune up time!, Sorry to keep bugging you guys but... |
Greg Bell |
Aug 14 2006, 07:28 PM
Member Group: Members Posts: 137 Joined: 3-May 05 From: Warner Robins, GA Member No.: 4,024 |
Guys,
I want to tune-up my trans. I replaced the fluid this weekend and that seems to have helped a good bit. Now, I want to clean it up a little more. I want to replace the bushings. 1. What parts do I need? I understand I need rear ball cap bushing and some lithium grease; (2) the two tapered screws, front and rear; (3) rear shift rod bushing??; (4) firewall bushing How about engine and transmission mounts? How hard are they to replace? What parts do I need? Guys, I want to order these parts so I can at least do the bushings this weekend. What parts should I order, and where do you reccomend? |
So.Cal.914 |
Aug 14 2006, 07:57 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I can not remember what year your 914 is. The mounts are not bad at all to
replace but do you need to. unless your shift pivot points have air tight dust covers, use a dry lube or none at all. Wet lube will attract dust and that will wear out parts real fast. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:34 PM |
