> Tailshifter Linkage Woes, Can't get 1st, 3rd, nor 5th
Mockmaw
post Oct 17 2003, 11:37 PM
Hi all,
New engine is up and running, all very exciting. Problem is: I can't shift into 1st, 3rd, or 5th gear.
I fiddled extensively with the shift linkage today.. seems adjusting the shift linkage in the 2nd-3rd plane didn't make a difference. I can shift into reverse, 2nd, and 4th fine.. when I try to shift into 1st, 3rd, or 5th it takes a huge amount of effort and finally pops 'in'.. but it's not actually in gear.. you can feel a bit of grinding if you push the shifter further towards the rear of the car, but it won't go into gear.
This is pissing me off.. suggestions?
Red-Beard
post Oct 18 2003, 04:59 PM
"Ya canna change the laws of Physics"
Better yet: SPend the money and get a side shift tranny....
Mockmaw   Tailshifter Linkage Woes   Oct 17 2003, 11:37 PM
URY914   When you put the shift rod back in the coupler (at...   Oct 18 2003, 01:44 AM
2teeners   I was having some troubles too. It was inside the...   Oct 18 2003, 06:03 AM
Mockmaw   Engine is: 66mm Crank, 96mm P+C's (1911cc) 2....   Oct 18 2003, 09:24 AM
rhodyguy   get the f.i. fuel line clamps. how did you plumb t...   Oct 18 2003, 09:34 AM
Mockmaw   I just replaced that damn roll pin twice in the la...   Oct 18 2003, 09:40 AM
rhodyguy   as people jam it into gear the stupid thing bends ...   Oct 18 2003, 10:00 AM
2teeners   if the shift linkage is too long, it won't all...   Oct 18 2003, 10:17 AM
rhodyguy   well put. as the pin bends in the 1,3,5 the whole ...   Oct 18 2003, 10:24 AM
Bleyseng   Nice looking engine! Where does the heads vent...   Oct 18 2003, 10:30 AM
Mockmaw   Okay, it's not the roll pin.. I took the linka...   Oct 18 2003, 10:33 AM
rhodyguy   one down. did you replace the cup in the bottom of...   Oct 18 2003, 10:45 AM
Mockmaw   The cup at the bottom of the shift lever was repla...   Oct 18 2003, 11:07 AM
Mockmaw   Okay, with the car over the pit.. The rear shift ...   Oct 18 2003, 11:34 AM
McMark   Fuel Injec tion hose clamps: http://www.napaonlin...   Oct 18 2003, 12:11 PM
Mockmaw   Can someone enlighten me on the difference between...   Oct 18 2003, 03:00 PM
MarkV   The non-FI hose clamps have slots that cut into th...   Oct 18 2003, 03:03 PM
2teeners   That's a nice motor. How does it feel with al...   Oct 18 2003, 04:50 PM
Red-Beard   Mock: Somehow you've shifted the engine and t...   Oct 18 2003, 04:58 PM
Red-Beard   Better yet: SPend the money and get a side shift t...   Oct 18 2003, 04:59 PM
Mockmaw   The spending of the money to get the sideshift tra...   Oct 18 2003, 05:04 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 12:23 PM
