Build your own Combo (904) Gauge, Parts 1 and 2 |
914forme |
Apr 23 2006, 06:48 PM
Well here it goes the step by step instructions on how to build one of the kits. Since I helped do the original production run, back in the day, its been about 11 years ago since we did these. But there is interest in it so I will show you how.
Step one, the original kit. It included a gauge face, a backing plate and a ground lug. Also included instructions on how to do this, and some of the items where real PITAs to do. I will included some changes I do, and items that might make the installation a little easier. Attached image(s) |
914forme |
Aug 17 2006, 07:55 PM
Again my Sir Andy school of photography is paying off!
Next you need to cover that back woods engineering! If you want the black flat face, mix up a little filler and fill it , and paint it. Or do as I do, use a silver button, and paint it black, I like a profile change, adds a little depth and dimension to the gauge. For this one I needed a silver button, so that is what I did. In the instructions it says to drill out the silver button. A little tip is the silver button is mounted on a steel rivet. You can gently pry the two apart. Use your fav glue and put it back on. I used Valco HV-350 It will glue about anything to anything, and is paintable if you get messy. Add a dab of glue and hide that screw! There you go you will not know that screw was there now from the outside. (IMG:style_emoticons/default/ph34r.gif) Attached image(s) |
Lo-Fi Version | Time is now: 5th June 2024 - 09:41 PM |
