wrench size question... HELP |
VaccaRabite |
Aug 25 2006, 01:58 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, I am taking off the rear suspension bits. What size is the bolt that connect the shock to the rear control arm. Also, what size are the two bolts (or bolt / nut) that connect the control arm to the body of the car?
I have metric wrences up to 17mm, and these are bigger then then that. Haynes did not have the size when I looked. So beofre I go out and spend money on large meteric wrenches that I may never use, I thought I'd ask here. my car is a 76, if that makes any difference. Thanks Zach |
SLITS |
Aug 25 2006, 02:07 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Shock bolts are 22 mm as I remember .... the others may be the same.
An SAE wrench will fit, but I don't remember the size until I go to use it. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:43 PM |
