bcheney |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States ![]() |
I have reconditioned the front suspension on my 75 914 2.0. everything has been powdercoated, a arms, carriers etc. I have installed new plastic poly bushings into the main carrier (the one closest to the steering rack). I am trying to install the a arm now and have had my ass properly kicked! I cannot get the a arm to slide into the bushing at the end closest to the steering carrier. I have tried constant pressure by hand arm and leg. I have tried tapping with a rubber mallet. The damn thing will not insert. It goes in about 1/4 - 1/2 inch and stops. Any tips???
(IMG:style_emoticons/default/smash.gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
powdercoating
you have now made the ID of the mounts smaller and the OD of the a-arm bearing surface larger......you'll have to figure out what part to sand/Dremel to get a decent fit. You want the bushing to rotate on the a-arm and be somewhat tight in the mounts(not a press fit, just enough to prevent rotation) |
Lo-Fi Version | Time is now: 12th July 2025 - 04:30 PM |
