Want to calculate torsion bar rate, Need a working formula |
914forme |
Aug 26 2006, 08:21 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Okay I am brain dead here, I tried to morph the one out of Fred Puhn's Book, but then I get numbers to the 10 and 11 power in foot pounds (IMG:style_emoticons/default/confused24.gif)
Any math wiz out there want to give this a try. Working hte last two days for 48 hours straight has done my brain no good. Here is the formula it can be found also in How to make your car handel page 142. =SUM(1,178,0*(D2^4)/L2*A2^2) D = diameter L is the length of the bar A lever arm length TIA, I am off to get some much needed rest Take care, Stephen Jacobs |
Borderline |
Aug 26 2006, 09:05 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
Stephen:
the basic fromula for a torsion bar is: angle of deflection=(torque * length)/(19691*d^4) "Angle of deflection" is in degrees. "Torque" applied to bar is in in-lbs. "length" is the effective length of the torsion bar in inches. "d" is the diameter of the torsion bar in inches. My numbers show the stock Tbar to be about 107#/inch at the wheel. A 22mm Tbar would be about 240 #/inch at the wheel. Hope this helps (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 10:50 AM |
