Anyone using 16" 5 lug fuchs? |
kenschipper |
Sep 4 2006, 05:35 PM
Member Group: Members Posts: 186 Joined: 5-May 04 From: San Juan Bautista, CA Member No.: 2,025 Region Association: Northern California |
Is anyone using 16" five lug Fuchs under standard fenders. What tire size and rim width will usually fit. Photos?
smj |
Sep 4 2006, 06:53 PM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
I have 16" Fuchs taken off an '86 Carrera, allegedly 16x6 up front and 16x7 in back. I've got Yokohama AVS ES100's mounted, 205/55ZR16 flavored.
The rear fenders had been rolled a bit, and that wasn't enough to clear the 225s the PO was running there. I haven't had the car back from the shop a week yet, but I'm still seeing some rubbing when braking and turning on the switchbacks up in the Berkeley hills. So, seems we really did need to take the spacers down a bit in front... I haven't taken the wheels off to verify the sizes, but if the above is correct than the fronts have an offset/ET of 36mm, and the rears of 23mm. Here's a link that lists a lot of info on the factory wheels: http://members.rennlist.com/911pcars/WheelWts.html |
brownaar |
Sep 5 2006, 03:45 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Bridgestone RE71 205/55ZR16 on 16X6. I'm thinking you have to use an early Fuchs, deeper offset I believe. Mine don't rub the fender, but do rub a little on the inner fenderwell with a really sharp turn-in.
Lo-Fi Version | Time is now: 5th June 2024 - 11:00 AM |
