terrymason |
Member ![]() ![]() Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 ![]() |
a couple of days ago my front brakes ran out of fluid - I did some inspecting, and I belive that my passenger caliper is bad. I've replaced the caliper, and went about bleeding it, but I can't get fluid in the lines.
I've taken the caliper off again, and am simply trying to get brake fluid out of the end of the brake line, just before the caliper. I've tried both pumping the brakes and using a vacum bleeder, and can't get and fluid out of the line. The level of the resovior never drops. So what is it? I'm assuming that there isn't a leak, could I have a bad master cylinder? Do I need to somehow prime this thing? |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,402 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Do you feel resistance against the pedal as you pump it?
Try bleeding the caliper on the driver side. See if you get B/F out of that one. |
Lo-Fi Version | Time is now: 11th July 2025 - 06:55 AM |
