Put in the 2.0 injectors in the 1.7, Won't fire :( |
Eric Taylor |
Oct 25 2003, 08:53 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
I just got finished putting in the 2.0 injectors, but no fire. Everything appears to be tight, and the
connections seam alright, but no fire. Any ideas? How long should I let the fuel pump go before hitting it? Eric |
fiid |
Oct 26 2003, 11:39 AM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
The higher flow rate on the 2.0 injectors will mean that you are constantly running rich. If you insist on doing this, you need to get a the appropriate calculators (Megasquirt has them - go to the megasquirt faq) and work out what fuel pressure you should run in order to get the same delivery as the 1.7 injectors. I would think it ought to be possible to back the fuel pressurer off enough that it could work, but you'd do much better to just pick up the stock injectors and run it stock. Or get a megasquirt, and tune it correctly.
Fiid. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:06 PM |
