2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
1975 2.0
The Motor is down and I might forget to re-install the Air Recirculation pump...But what do you do with the nozzles going into the cylinders and do they just screw out...I'm trying to remove the tin for repainting etc...??? Any suggestions ??? |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
The openings can be closed in several ways:
1. Remove head and weld closed. Remachine surfaces. 2. Remove nozzle and plug with threaded plug or bolt. 3. Remove nozzle and weld or braze nozzle closed, then reinstall. 2. Leave nozzle in place and screw threaded pipe cap over threads. Probably more but these I remember. Mike |
Lo-Fi Version | Time is now: 1st July 2025 - 01:56 PM |
