Instrument cluster removal, What is the trick for the wire going from the speedo to the dash panel |
Zimms |
Sep 28 2006, 09:29 PM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
Any help is much appreciated. I have the entire instrument cluster out but a cable running from the speedometer to the dash panel. What is this and how do i remove it?
Thanks, Mark |
GaroldShaffer |
Sep 29 2006, 07:42 AM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
You can also remove it from the speedo itself. The trip reset cables does come out of the speedo. All the ones I have seen have a white plastic sleeve that pulls out the back of the speedo. I was able to reinstall the cable and teh trip odometer worked just fine. YMMV (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 15th June 2024 - 06:50 PM |
