Tach question |
Tach question |
HCRDAN |
Sep 30 2006, 04:47 PM
Member Group: Members Posts: 113 Joined: 24-September 06 From: Austin, TX Member No.: 6,907 Region Association: None |
Any idea what the problem(s) might be here?
73 914 2.0L, not driven much by prior owner. Tach works intermitently. May work well for a while, then the needle gets stuck somewhere. Last time it was around 3K RPM, today at 2.2K. Then sometime in the future, it will start to work again. Second problem is the turn signal indicators in the tach. Sometimes they both flash, sometimes neither flash, when I put on turn signals. Signals on the outside work just fine. When I put on emergency flasher, all lights blink as they should on the outside, but nothing blinks on the indicator lights in the dash. Any ideas? Are these related or separate problems? Thanks DG |
Tobra |
Sep 30 2006, 05:38 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
perhaps dirty contacts on the signal indicator bulbs.
My tach does the same thing, I think it is a loose or corroded connection in mine, where it plugs into the back of the tach. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:43 PM |
