Flares, 5-Lug,Studs, Spacers and Tires!!, A little bit of it all under the fender. |
mharrison |
Oct 28 2003, 09:55 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Hopefully somebody has done this and has a good reference point to answer from:
I have a set of 7" Cookies that I want to put under my fiberglass GT flares. What size tires will fit, and when I convert the lugs to 5-lug, (via a drill and stud) will I need spacers? If so, how thick and what length studs? |
SirAndy |
Oct 29 2003, 12:21 AM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(mharrison @ Oct 28 2003, 07:55 PM) I have a set of 7" Cookies that I want to put under my fiberglass GT flares. What size tires will fit, and when I convert the lugs to 5-lug, (via a drill and stud) will I need spacers? If so, how thick and what length studs? 225/50 x 15 all around on 7" cookie cutters ... 1 1/4" spacer in the front 1 1/2" spacer in the back no long studs for me, i have spacers with studs pressed in. so, you bolt on the spacer using the original studs (spacer come with steel lug nuts to do so), then bolt your wheel onto the spacer. NOTE: i don't have redrilled hubs, i have real 5 lug back and front. (IMG:http://www.sirandy.com/pix/914/2003.10.01/08.JPG) |
Lo-Fi Version | Time is now: 11th June 2024 - 02:29 PM |
