Blinker problem |
Blinker problem |
vertigo |
Sep 27 2006, 09:02 PM
Member Group: Members Posts: 72 Joined: 12-June 05 From: Porterville, Ca Member No.: 4,262 |
'73 2.0 /recently when I turn blinker (to right) and press brake the blinker on dash dims and both flash. Release pressure on brake and it blinks normally. This only happens with right signal and not left. Has anyone experienced this before and if so what might be the fix? Thank you in advance.
vertigo |
Sep 28 2006, 08:35 AM
Sorry, yes both lights on cluster flash. The blinkers on outside remain correct. About 3 month ago I did change the return cog for the blinker, but it has worked fine until 3 days ago.
HCRDAN |
Oct 7 2006, 09:57 PM
Member Group: Members Posts: 113 Joined: 24-September 06 From: Austin, TX Member No.: 6,907 Region Association: None |
Sorry, yes both lights on cluster flash. The blinkers on outside remain correct. About 3 month ago I did change the return cog for the blinker, but it has worked fine until 3 days ago. I had similar problem. Replaced a flasher bulb (right front) maiking sure I had correct 2 filament bulb and that started a cascade of issues. Cleaning contacts on bulb socket helped keep fuse from blowing, but after that, both lights would flash on tach, while outside lights would flash correctly. Replaced flasher relay and that seems to have solved the problem |
Lo-Fi Version | Time is now: 11th June 2024 - 08:19 AM |
