Mini-starter goes "ping!", What the hell. |
LowGT |
Oct 9 2006, 11:12 AM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
So I swapped to a 2.0 and a new mini-starter and everything has been starting fine for the last two weeks. I went to tune the carbs last night and it started fine. After the car warmed up I shut it off to remove the carb linkage. (I think it's easier to adjust this way) When I tried to start it, all I got was a loud "ping".
I checked the battery and it was a bit low. I charged it all night and no difference, so I bought a new battery. Still only got the ping. So I check and clean all grounds, checked the voltage regulator wiring. Everything is in tip-top shape. Tried it start, PING! All the gauge lights dim like maybe the starter will turn, but it never does. I tried turning the engine by hand and it turns fine. It sounds like the starter gear is just coming out and hitting the flywheel, and never turning. Any ideas? |
John |
Oct 9 2006, 11:27 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Did you whack it with a wooden mallet?
It sounds like the starter motor has a stuck/locked rotor. I bet the amp draw is incredible. Don't try starting it for too long in this condition. The easiest thing to do would be to drop the starter out and bench test it outside the car. You might want to call whoever you bought it from. Isn't it warrantied? |
Lo-Fi Version | Time is now: 7th June 2024 - 08:15 PM |
