> Turn signal indicators wired wrong?, Both arrows flash at same time.
william harris
post Oct 9 2006, 03:55 PM
914 Restorer
What is wired wrong inside my tach? The turn signals (outside) work just fine. But inside the indicator arrows both flash at the same time no matter which way you are turning. I also am having the problem with the signals not cancelling out, even though the little tab on the back side of the wheel is installed properly. Works once in awhile, but not almost all of the time. Well, guess I got to have something to fuss over. (IMG:style_emoticons/default/confused24.gif) Suggestions anyone???
DanT
post Oct 9 2006, 04:01 PM
Going back to the Dark Side!
what year car? the later years operated in that manner. Both arrows flash at the same time regardless of direction....
That way they only had to install one bulb instead of two with an appropriate 2nd circuit. (IMG:style_emoticons/default/dry.gif)
- Lo-Fi Version Time is now: 17th July 2025 - 03:14 AM
