Definition of Minimum Weight, Whats SCCA's official line |
Rough_Rider |
Oct 12 2006, 01:55 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
I was told years ago never to ask a question i didn't want to know the answer to. As i don't want to feel as if i'm cheating i gotta ask
What is SCCA's official line on minimum weight. Does it include driver or No? Furthermore it doesn't specify if this is a dry (no oil, fuel, or other liquids) or wet weight. Searching 2006 rule book I see 55 references to min weight but only 2 that specify a definition & they contradict each other ! (IMG:style_emoticons/default/screwy.gif) p130 Min weight is with driver for modified catageroy p174 min weight is without driverfor modified XP catageory FYI, 914 in XP = 1200lb, +200lb per liter, +20lb per liter mid mount engine) Eg 2.7 = 1200 + 540 + 54 = 1794 lb |
Dave-O |
Oct 12 2006, 04:48 PM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
What is SCCA's official line on minimum weight. Does it include driver or No? Furthermore it doesn't specify if this is a dry (no oil, fuel, or other liquids) or wet weight. The answer is yes (IMG:style_emoticons/default/biggrin.gif) . In some classes it is with driver, the others are without. I know that XP is without driver but some other classes like FM are with the driver, you have to look at the individual class. The minimum weight is for a ready to run car. If you go to a national tour event or nationals all cars in classes with minimum weights are weighed after running. You want to make sure that you will be heavy enough AFTER you run. Hope this helps, |
Lo-Fi Version | Time is now: 11th June 2024 - 02:33 AM |
