> Bursch exhaust, AKA: dumb newbie questions
Scott H
post Nov 1 2006, 09:32 AM
Luddite
I have a '72 that's been parked since back around '85. I'm using this car as a learning tool to learn my way around a 914.
The PO gave up on the car while in the middle of converting it to carbs and just let the car sit and rot away. He had bought a Bursch exhaust at the time that he said he thought was the wrong one and he never got around to exchanging it for the correct one. This exhaust has been sitting inside the car all that time and was never even bolted onto the car.
The exhaust has a sticker on it that says "914 73-74" and I see that Pelican Parts sells '70-'72 and '73-'74 Bursch exhausts so it looks like it is indeed the latter and the wrong one for a '72 (I'm sharp today (IMG:style_emoticons/default/biggrin.gif) ). Pelican only shows a picture of one exhaust.
My question is: what's the difference between the two? If I hold this exhaust up to the ends of the heat exhangers it appears that it will bolt up. The rear valence is not on the car, so it looks to me like the tip of the exhaust would hit the valence if it were in place.
Is that the only difference between the two?
If it helps, here are some pictures of the one I have:
http://smg.photobucket.com/albums/v134/sdc...rsch%20exhaust/
Thanks for any help.
**edit: I didn't notice the other Bursch topic until after I posted mine. If a moderator wants to move my post over there, that's fine by me.
jd74914
post Nov 1 2006, 10:37 AM
Its alive
I could be wrong looks like a 1.7/1.8 unit to me. I'd just try bothing it up and seeing what happens. If it fits, then its good. Don't worry about how its labeled. The only differences between early style ('70 to '74) systems in relation to engine dispacement (ie: 2.0's are different that 1.7/8's) but you would know. The flanges are the same but i believe the muffler won't fit on ifs its not the right model.
Again, try it and see.
Edit: I was beaten.
- Lo-Fi Version Time is now: 2nd July 2025 - 01:12 PM
